Loading [MathJax]/extensions/Safe.js
Author Topic: Calculate damping frequency  (Read 11206 times)
Online TimFox
Re: Calculate damping frequency
« Reply #25 on: February 10, 2021, 04:05:09 pm »
22 x 10+3 = 22,000 (American convention) and 350 x 10-9 = 0.000000350.  Have you never seen this notation before?  For the latter, the exponential notation is far easier to read.  My -hp- calculators have two options:  “eng” uses only powers of ten divisible by 3, and “sci” uses multipliers between 1 and 10.
Offline Jan AudioTopic starter
« Reply #26 on: February 10, 2021, 04:25:54 pm »
Ok thanks here we go :
2 * 3,1416 * 22.000 * 0,000000350 = 0,04838064
1 / 0,04838064 = 20,66942479471127
Maybe 0,000000350 should be 0,000000000350 for 350 pf i guess.
Ok
Online TimFox
« Reply #27 on: February 10, 2021, 04:38:49 pm »
Yes, going to pF adds three more zeros before the significant figures.  Expressed that way, it is very difficult to understand the value.  When far from unity, values should be expressed either in exponential notation or using prefixes such as “n” or “M” in front of a unit such as “F”.  If the number is dimensionless (such as 3.14159265), prefixes have nothing to modify.
« Reply #28 on: February 10, 2021, 04:55:24 pm »
Nice, now i can make all my filters in the audiopath 18K to 20K.
Only that forms a more pole filter wich changes the computation ?
If i add 2 of these filters in series then i dont have a 2 pole filter on that exact frequency ?, so weird.
Offline RandallMcRee
« Reply #29 on: February 10, 2021, 06:59:24 pm »
Use a filter calculator?
Buy a hand calculator?
Online TimFox
« Reply #30 on: February 10, 2021, 07:30:07 pm »
Or, enter the equations into Excel or other spreadsheet?
Offline srb1954
  • Retired Electronics Design Engineer
« Reply #31 on: February 11, 2021, 05:02:08 am »
1/(2 x 3.1416 x 22 x 10+3 x 350 x 10-9)  = 20.7 Hz (American convention on decimal points.)
Thanks, what does 22 x 10+3 x 350 x 10-9 in normal numbers ?
These are normal numbers in scientific or engineering notation. If your calculator can't handle these throw it away and get a proper scientific calculator.
