Hi all,
Dredging up an old topic, but I found
this post on precision resistor networks used as range switches in volt meters yesterday and it exactly answers about 4 different questions I had all in one. But it leaves me with some more.
Lets consider current flow for a moment. Looking again at the 1V input, with the range switch set to the lowest divide ratio of 10:1, that 1V is flowing through a total resistance of 11.111...Mohm. I make that a current flow of 90nA. What sort of analog switch chip are you going to use for that?
I see "leakage current" of channels specified sometimes in units of nA already (e.g. the randomly-picked MAX351 guarantees to source or sink no more than 0.4nA, which is 0.4% of our signal here). Does that matter? I admit I don't quite understand what the leakage current is measuring, and whether it's important in this application.
Given our switch is shorting a resistor to the low-impedance ground supply, I don't think charge-injection is an important parameter here, as ground will conduct that all away.
Channel resistance is fairly important, at least at the highest end of the divider chain - a 10ohm channel on that 1K resistor is a massive 1% of error. Maybe on higher ratio / lower resistance end of the chain we'd be better off using discrete FETs instead of an analog switch part?
Can someone suggest a suitable analog switch we could use for precision voltage measurements based on this sort of divider?
