Author Topic: Multi-sourced RJ45 ethernet jack?  (Read 528 times)
Offline globoyTopic starter
« on: June 27, 2022, 05:48:57 pm »
I'm designing my first POE device and looking at parts selection.  Lots and lots of different RJ45 connectors.  I'm hoping to tap some of your collective experience to find out if there is a part or parts that are essentially multi-sourced (same footprint).  My application is a bit cost sensitive so I'm looking for a basic single-port type.  Ideally it would have the yellow/green LEDs and shielding (but open to other possibilities).  Doesn't have to have magnetics.  Can be top or bottom entry for the connector tab.  Right angle, PCB mount (either SMT or TH is ok).  POE power is < 5 W.
What are your go-to part numbers?
Offline thm_w
  • Non-expert
The following users thanked this post: globoy
Re: Multi-sourced RJ45 ethernet jack?
« Reply #2 on: June 28, 2022, 02:21:10 pm »
Thank you thm_w.
