I applied +4V to RUN pin, and got +4.7V. Looks OK to me... I also removed the heatsink, looks like all ICs have correct orientation. IC9 has alignment issues, but looks to have a good electrical contact.
So, I guess, further troubleshooting requires installing it into the power supply? Or there is a simple way to output some test voltage? It seems I need to send some SPI commands to do so.
PS not sure if it matters, but both CV and CC LEDs are on.
