I was looking to adjust the amplitude a 350khz sinewave signal....Digitpots seem way to frequency limited unless I pick a lower resistance version. DAC seem to be frequency limited on the verf as well, although not a badly as digipots...does this mean I have to go the MDAC route for frequencies above say 100khz? Or am I just searching digikey the wrong way and need to search deeper? I have no issue using MDACs, just rather not have to deal with the output amp (trying to use the least number of parts possible).
