Finally found something interesting as a first project outside the sub-field of repair.
Some time ago I found a PDF scan of the Philips PM5530 sync generator service manual. After much reading to get an idea on how the device works, the document seems to provide enough information to build the generator from scratch! I don't exactly expect this to be a breeze though. The original design uses copious amounts of germanium goodies, with silicon parts mixed in. A number of so-called "circuit blocks" were also used, which in themselves are going to represent a challenge as I can only find internal schematics sans values (but they do provide data on the input and output signals). They're basically a mix of analog and DTL circuits.
I'm fully aware that the functions of this rackmount dinosaur could all fit within a minuscule FPGA nowadays, though my goal with this project is to substitute the ancient semiconductors with modern, inexpensive parts and tweak the passives around them to make the whole thing work. A sort of electronics (re)design challenge, if you will.
And most importantly, an opportunity to gain deeper knowledge. I also plan on documenting the entire process in the form of videos, including the fails.
Before I truly dive into this
madness endeavour, any advice on potential difficulties arising along the way? I don't see huge obstacles ahead but maybe there could be some.
(Just so you know, I do have formal background in electricity, with introductory courses in AC and DC circuit analysis and electronic components, among others. I wouldn't even consider trying this if I didn't at least have enough knowledge to know where to start!)
