FlameIT - AC Mains and Zero Crossing Precision Detector
Module GitHub repo:
https://github.com/flameit-os/ac-mains-and-zero-crossing-detectorIf anyone is interested in buying one (or more
) do not hesitate contacting me.
!!! Caution !!!
This module was design to connect directly to the AC grid power.
Its misuse might cause ELECTRIC SHOCK or FIRE.
!!! Caution !!!
SchematicsOriginal concept was created by Dextrel. This module has extra imput protection and MDL (Mains Detection Logic) output.
https://web.archive.org/web/20180209005931/http://www.dextrel.net:80/diyzerocrosser.htmFeatures- very accurate mains zero crossing detection
- fully isolated (5kV optoisolation)
- low voltage, safe output (low side can be supplied with voltages from 1V up to 16V)
- ultra-low power consumption; worst case power dissipation < 120mW
- produces symmetrical pulses around the zero crossing
- very low parts count, no precision components required
- all components can be low voltage SMD
- works over all mains voltage ranges (100VAC...240VAC), without any modification
- both 50Hz (1,2ms ZC pulse) and 60Hz (1ms ZC pulse) mains frequency compatible
- highly stable with varying temperature
- ROHS compliant (Pb-free)
- extra AC input protection (fuse and varistor)
- 4 independent AC inputs on one module
- 2 low side outputs for each AC input
ZCD - Zero Crossing Detection pulse (HIGH level pulled to GND)
MDL - Mains Detection Logic (HIGH when mains is detected)
- spring clamp system terminal blocks on input and output
- extra goldpin outputs on low side
Use cases- Mains detection (logical output HIGH when phase is available)
- Mains frequency monitoring
- Checking of connection order of three phase systems
- Checking shift between phases
- Detection of power failures
- AC motor monitoring
- ...and others (check original Dextrel page for more applications):
https://web.archive.org/web/20180209005931/http://www.dextrel.net:80/diyzerocrosser.htm SimulationCircuit Simulation:
https://tinyurl.com/yasss96pTesting real modulePhase Order DetectionTurn ON / OFFMains Detection LogicZero CrossingZero Crossing with Mains Detection Logic
