The quest continues.
The newly built GPSDO (same base PCB as the previous version) was run for a week, then shut down to fit the MAX6350 5V precision regulator. A few days later we went away for a week and I left the PC on, recording data from both GPSDOs.
The software in the older GPSDO was modified to provide drift compensation. As noted before, this is probably a waste of time but it is now debugged and working. It is quite simple - the nominal control voltage (a 24 bit variable) is added every second to an accumulator (creating a 48 bit sum). This is subtracted from the accumulator for the previous day (at UTC 000000 - trivial information), the difference divided by 86400 to get the difference between the average voltage for the 2 days. The difference is multiplied by 65536 (2^16) then divided by 86400. The result is (the change in control voltage)*2^16 to be applied each second (multiply by 2^16 because it is much less than the least significant bit of the 24 bit number). That result is then added to a 16 bit variable every second, when the 16 bit variable overflows/underflows then the 24 bit control voltage is increased or decreased by 1. This usually happens at intervals of hundreds of seconds, each change equates to a frequency change of about 3 parts in 10^-13 so has almost no effect short term but over many minutes has a tiny effect which *may* be beneficial.
Ten days of data was collected from the system with the precision regulator, the results are in the chart attached. The top line clearly shows when we came home, the voltage wiggles up and down for 3 days. This is likely due to daily temperature variation - while the house was empty it would be little affected by the weather outside, but once we opened a few windows and doors, the inside temperature would change more. Which leaves the question - is the gradual rise due to the house slowly warming, or is it oscillator drift. The good news is the regulation kept the oscillator 10MHz±1mHz for almost all the time, including when we were in the house.
After changing from a quadratic to a linear curve fitting algorithm for averaging results, there was no need to take three successive averages of the phase errors, two would be enough. So the algorithm has been rewritten yet again, in the last few days, to use two averages. An explanation: if the two averages are A and B then B-A gives the phase change between the two averages. A phase change is caused by a frequency error. If the phase change is D, then the phase error at the end of the two measurement periods is (A+B)/2+D. Compensating for both should drive the oscillator to zero phase error with respect to the GPS. In reality there will be a residual at the end of the next measurement period so the process is repeated.
The averaging is done over 2 periods of 2^n seconds, currently trialling n=10, two periods of 1024 seconds. Initial results are that this is a bit long, it gives the OCXO time to wander too much. The algorithm catches the wanders, but it is preferable to set the maximum period for least wander - a compromise between gathering enough data points to iron out second by second GPS variability, and allowing the OCXO too much leeway to wander off. The three point algorithm seemed OK with 3 periods of 512 seconds, so 2 periods of 512 seconds may be better.
There isn't much to do now with this design. I believe it is as cheap as a GPSDO can be, and still produce 10MHz within 1 part per billion and verify it. There are many designs on the Internet, but I have not seen one that can measure its own performance the way this one does. Anyone can count cycles for 10,000 seconds and say on average the design is producing 10MHz within a certain tolerance. But with a 16 bit DAC and corrections applied every few seconds or minutes, there is no way to verify the frequency at any point in time, except by comparison with a better standard (GPS locked rubidium or cesium).
Further development is feasible (try to correlate GPS position errors with GPS 1pps errors) but is there a point? I have asked in the past if anyone has a use for better than 1 part per billion in a hobby situation but not received a sensible reply. So I am thinking in a month or two I'll close off this thread. Maybe with a report of some description. What do people want to know that I haven't already covered?
