Author Topic: Slow Blow or Fast Blow fuse?  (Read 693 times)
Online ricko_ukTopic starter
« on: September 22, 2020, 06:54:28 pm »
with reference to the attached schematic, would you recommend a slow blow or fast blow?
I was thinking that when initially the circuit receives power C14 and C15 are discharged and there might be a (relatively) large current surge. So a slow blow fuse might be better?
But then again the current surge might be too short to need a slow blow?
Or maybe I should think in a different way when coming to choose the type?
Thank you :)
Online Benta
Re: Slow Blow or Fast Blow fuse?
« Reply #1 on: September 22, 2020, 07:39:33 pm »
Doesn't matter. You'll never have more than 13 mA running through it.
The following users thanked this post: ricko_uk
« Reply #2 on: September 22, 2020, 08:45:16 pm »
Thank you Benta, :)
I got that schematic from a reference design. The fuse is set to 1A, I assume in case any components downstream fail. What do you mean never have more than 13A?
Do you mean because R11 and R12 would limit the current? I thought the fuse is there perhaps in case R11 and R12 short?
Sorry but not much experience in mains design and requirements.
Thank you
Offline james_s
« Reply #3 on: September 22, 2020, 09:43:58 pm »
13 *milliamps*, that's 0.013 amps. You've got 30k worth of resistors in series which will limit the maximum current according to Ohms law. I would consider just using flameproof resistors and skipping the fuse.
Online Benta
« Reply #4 on: September 22, 2020, 09:44:49 pm »
The fuse is good practice (and depending on your electric code rules) for fire protection. It's not there to save your circuit.
Offline james_s
« Reply #5 on: September 22, 2020, 09:50:32 pm »
They make flameproof resistors that are designed to function as a fuse, sometimes they're called fusible resistors. They're quite common in low power applications like that.
