Lower supply inductance (but, higher ground inductance -- yuck!!)
More convenient, better heatsinking (substrate is drain, on modern VDMOS and etc.)
More clearance (though I've seen 100V capable controllers in TSSOP, so that doesn't matter)
Why would the area be tiny? If you need cooling, you make that pour as big as it needs to be...
