Ok furthur looking has found better options with analog devices, looks like the 9V minimum is pretty fixed, (and there is a quirk where the positive trigger has to be between VCC and VCC-4.5V, Which means a charge pump splitting 5V to +-5V makes an ideal solution, low RSon, and a wide protection range,
I'll leave this up for any who come later,
