Author Topic: Component identification (led driver)  (Read 1338 times)
Offline vinicius.jlantunesTopic starter
  • Country: br
« on: January 20, 2018, 03:27:56 pm »
Hope someone here can help me identify this component.
It is in a LED driver circuit from a small 5W light fixture. The code in the package is 26453 (and 9420 at the top which I suspect is a the fab date?).
The schematic is very simple, also attached. When fed with 127VAC it's output is ~170 VDC. I believe it is a constant current LED driver or a regulator wired as a constant currrent source. What caught my eye though is the fact that it can take a high input voltage (basically rectified and filtered mains, no transformer).
I have salvaged 6 of these from a dumpster and the LED's are fried in 5 of them, but I want to reuse the fixture and put new LED's on it. So I would like to reverse engineer the driver circuit and adjust accordingly.
The driver circuits seem to be all working, so I just wanted to see if I can adjust its current by changing the feedback resistor R1 so it matches whatever new LED's I put in it (most likely a small string of SMD LEDs that I have laying around, in series).
Offline amyk
Re: Component identification (led driver)
« Reply #1 on: January 20, 2018, 05:11:07 pm »
Winsemi WS9420.
Your schematic shows the diode backwards.
The following users thanked this post: vinicius.jlantunes
  • Country: br
« Reply #2 on: January 20, 2018, 06:55:38 pm »
Thanks!
And about the diode too, doh!
