Author Topic: Bridge rectifier with selectable output polarity  (Read 2149 times)
Offline hkBattousaiTopic starter
« on: May 25, 2014, 03:02:29 pm »
I need a bridge rectifier block whose polarity can be chosen by a control signal.
I came up with the following circuit.
I would like to know if there is an alternative method for this.
« Last Edit: May 25, 2014, 03:24:34 pm by hkBattousai »
Offline dannyf
Re: Bridge rectifier with selectable output polarity
« Reply #1 on: May 25, 2014, 03:20:18 pm »
An H-bridge works. Save one set of rectifiers.
« Reply #2 on: May 25, 2014, 03:41:35 pm »
You mean this, right?
Brilliant idea. Thank you a lot!
