Author Topic: Entrelec terminal footprints are upside down when inserted at 90 degrees  (Read 734 times)
Offline danjenkinsTopic starter
Just FYI for anyone using Entrelec terminal blocks. The footprints that are included with AutoCAD Electrical are rotated 180 degress in the wrong direction. When you insert at a 90 degree angle for a horizontal DIN rail, you will notice that the screwdriver slot for removing the terminal is on the top. Try inserting an M4-6 and you will see what I mean. http://www.clrwtr.com/PDF/ABB-Controls/ABB-Screw-Clamp-Terminals.pdf Even the End Stop is upside down. I edited the Entrelec blocks I use and rotated them so they look correct now. But there are many more to do.
