I'm not looking for a specific design for one single thing, just to find some "jellybean" go-to options to consider that are inexpensive (for one off or very low volume personal / hobby stuff) and good to use & work with for a variety of miscellaneous outdoor equipment which should be protected from the weather and environment. Basically I'd like to identify good options for many things ranging in size from less than the size of a deck of playing cards (e.g. 75x25x50mm or so) ranging up in many steps up to the size of a loaf of bread or so.
I'm sure there are some popular options from manufacturers or surplus or resellers etc. like ebay, aliexpress, mpja, digikey, whatever.
The plain old solid rectangular prism plastic or metal box with a gasket or tight fitting lid is easy enough but then there's
also the use cases where one may want things like cable glands, transparent lids for small displays / lighting / indicators / sensors, etc.,
better heat sinking / dissipation to the environment by passive cooling, not RF blocking materials, mounting tabs / flanges / etc., etc.
So basically what do hobbyists these days like to use for their personal controller / UI / IoT / sensor / network / instrument / lighting / solar
etc. types of projects that are supposed to survive out around the house / deck / patio / yard etc.?
Some sorts of examples which aren't particularly novel but easy / fun personal projects:
temperature / humidity / pressure sensor, near-freeze detector, anemometer, wind direction / speed sensor, rain / snow / water fall or rate or depth detection,
UV index / daylight meter, lighting controller, vehicle sensor for gate / driveway lighting / intercom etc. interface, small scale illumination / indicators,
weather sensor / display with some small eInk or other display, etc. etc. etc.
So basically plastic with options for glass or transparent PMMA / acrylic faces if not the whole thing made of such would be handy for various such projects,
while others could be suited for a more generic opaque plastic option.
Ideas / suggestions / examples for enclosure / materials products & ME / ID design ideas will be appreciated & welcome, thanks in advance!
For those who have done this sort of thing recently for hobby projects, what has been your experience with things like humidity,
condensation, mold etc. impacting the contained projects over time? Did you use any kind of encapsulation / conformal coating etc.?
