Author Topic: Where to get multimeter knob contacts?  (Read 2988 times)
Offline rea5245Topic starter
« on: September 07, 2020, 07:15:33 pm »
You know the contacts on a multimeter knob that brush against the PCB (pictured below)?
What are they called? Where can I buy them?
Thank you,
   Bob
« Last Edit: September 07, 2020, 07:17:30 pm by rea5245 »
Offline MosherIV
Re: Where to get multimeter knob contacts?
« Reply #1 on: September 07, 2020, 08:21:24 pm »
They are known as spring contacts.
Not sold anywhere that I am aware of.
Offline bob91343
« Reply #2 on: September 07, 2020, 08:33:36 pm »
You probably will have to buy or salvage some beryllium copper or phosphor bronze parts of the approximate thickness and cut them to shape.
« Reply #3 on: September 07, 2020, 09:29:18 pm »
Every multimeter has them. There must be someone manufacturing them.
Offline floobydust
« Reply #4 on: September 07, 2020, 10:53:25 pm »
Those are crap! chinese low purity copper which on gold ENIG pcb I find does not give a decent connection. They have won the race to the bottom for price and quality.
Are you looking for replacements or building something using them? If they were leaf/cantilever style, at least silver-plated the quality would be good.
« Reply #5 on: September 07, 2020, 11:41:44 pm »
Those are crap!
So are multimeters experiencing a high failure rate? Or do higher quality multimeters use a different mechanism?
I want to build something that uses a multimeter-like rotary switch. But if there's a better alternative, I'd love to hear about it. (My current prototype uses an off-the-shelf rotary switch, but it's more expensive than multimeter rotary switches, and it doesn't have quite as nice a feel to it.)
- Bob
Offline floobydust
« Reply #6 on: September 08, 2020, 05:15:44 am »
Something about them I have constant problems with oxidation and a poor connection even with DeOxit on them. The copper has a dull look about it. It depends on what signal you are pushing through them.
It's a primitive switch contact- any high quality rotary ones have silver or gold plating (Brymen, Agilent, 121GW appear gold coloured). Better Fluke multimeters have their own patented switch mech with I think phosphor or nickel plate and more precise, refined fingers. Fluke started out with an off-the-shelf rotary switch in their earlier handhelds.
Some people strip a cheap Harbor Freight $4.99 special and use those, or this guy documented making his own. https://softsolder.com/2012/09/20/multimeter-range-switch-contacts-whoops/
If you can make the rest- the knob/ratchet maybe 3D printed it would be neat.
They are part of a switch which is part of a multimeter. Switch manufacturers only sell the entire switch. I searched but could not find a specific company offering them, which would save tooling and die cost.
Offline janoc
« Reply #7 on: September 08, 2020, 09:25:18 am »
They are likely custom parts.
