Thanks for all of your replies.My application is DC. I want to measure the current into and out of my motorcycle battery. It is a lithium-ion battery with built-in battery management (that's what they claim). I suspect that there is a parasitic current draw as well.Initially, I want to try using a Sparkfun OpenLog Artemis. https://www.sparkfun.com/products/16832The problem is the ADC of the Artemis has a maximum allowable input of 2 volts, so I have to scale the output of the current sensor to match the Artemis.
