Author Topic: Probing noisy signals to the scope  (Read 866 times)
Offline FaringdonTopic starter
« on: October 31, 2023, 10:53:33 pm »
You are (scope) probing some signals on a board with an offline SMPS on it. Signals are  on the primary side. You feed the kit via an isolation transformer, so you can use your DIY  coaxial probe to probe one of the signals without it being caked in  common mode noise. However, the other signal is referenced to a different node, so you cant use another coaxial probe into the scope.
You’ve already added extra Y caps across the transformer, and from downstream  side of common mode choke to earth (the board’s earth connection is capacitive). You’ve even added an extra common mode choke to the boards input…you’ve also wrapped the diff probe wires through a torroid…but that second signal is still very noisy as youre looking at it with the diff probe.
To get the second signal  less noisy, would you say its best to then make your own diff probe out of an opamp in diff connection with 4 MEG input resistors, and use coaxial cable to port the signal to and from it? (ie not the noisy diff probe connection leads)?
Or is there a cheaper way to get the second signal less noisily scoped?
'Perfection' is the enemy of 'perfectly satisfactory'
Offline jonpaul
Re: Probing noisy signals to the scope
« Reply #1 on: November 01, 2023, 07:47:04 am »
TROLL WARNING: See all the 1000s of posts by the same OP, in Power or Projects and other EEVBlog sections.
Just another FTTS (Farrington Treeze Time Sink).
No answer will ever satisfy this longterm troll.
This thread will never reach closure.
HAVE AN ABSOLUTELY FANTASTIC DAY!
Jon
Jean-Paul  the Internet Dinosaur
The following users thanked this post: tooki, Faringdon
Online tggzzz
« Reply #2 on: November 01, 2023, 09:07:01 am »
Jon
Seconded.
In this case the effective double post is https://www.eevblog.com/forum/beginners/wound-torroids-not-useable-as-scope-lead-common-mode-chokes/msg5145261/#msg5145261
This question is double posted at https://www.eevblog.com/forum/projects/probing-noisy-signals-to-the-scope/msg5145303/#msg5145303
For background, see https://www.eevblog.com/forum/renewable-energy/mains-zero-cross-detector-pulse-issue/msg5127057/#msg5127057
Think about the better place to reply. Or not reply.
« Last Edit: November 01, 2023, 09:34:20 am by tggzzz »
« Reply #3 on: November 02, 2023, 09:43:56 am »
Another measure may be adding one of these to the mains input cable, that feeds the SMPS/PCB...a chaper version, with more common mode filtration, anybody tired it?
https://www.dem-uk.com/roxburgh/Data/Product_Downloads/roxburgh-res20f10-chassis-mounted-high-differential-mode-filter-data.pdf
....Thanks, I appreciate the will to see  the Forum Ban be delivered uponst myself. Though I  am currently helping an Aussie guy do his Power Factor Corrected LLC converter (look in my personal mails if you wish). I have helped him with the PFC bit, and now I am busy so will return to deliver the LLC for him later….may I be granted a “stay of execution” until I have assisted this Aussie guy through his PFC/LLC?
« Last Edit: November 02, 2023, 07:36:57 pm by Faringdon »
Offline Buriedcode
« Reply #4 on: November 02, 2023, 02:11:54 pm »
Photo of your test setup would be helpful.
The following users thanked this post: Faringdon
Online tggzzz
« Reply #5 on: November 02, 2023, 03:53:57 pm »
What are you talking about?
I have no desire to see you banned. I would prefer it if you didn't repeatedly do things that are sufficiently antisocial that they might lead to yet another ban.
How the hell do you think I could look in your PMs? Unsurprisingly I have zero desire to do that!
I would have thought using emails would be the best way to help that Aussie guy; PMs on this forum seem too roundabout. But that's between yourself, the other party, and the forum admins.
« Last Edit: November 02, 2023, 04:44:05 pm by tggzzz »
The following users thanked this post: Kean, tooki, Faringdon
