Author Topic: BLDC buck conversion, where is the power going  (Read 303 times)
Offline InfravioletTopic starter
« on: July 18, 2024, 04:06:53 pm »
I'm trying to consider the efficiencies, and lack thereof, involved in powering a brushless motor (very low resistance coils, kV value around 1000 in volts/rpm). When you are using the half-bridges, one on each of the 3 "legs" of the motor, such that each goes to the Vcc higher voltage supply for a fraction A of a cycle, and to ground for a fraction B of a PWM cycle, assuming the time C during switching over between the two half-bridge states is short in comparison, then why, at standstill, or slow speeds where the rate of rotation isn't generating substantial back-EMF, can't you get "limitless" current at zero voltages from a Vcc power supply of nearly zero amps at whatever voltage (5V, 12V, 24V...) Vcc is?
For conservation of energy the current from the power supply by the voltage of the supply I_sup*Vcc will be, ignroing switching losses equal to I_coil*V_coil. Where I_coil is the current recirculating within the coils, averaged over time. The current leaving all the coils to return to the power supply's ground will ofcourse be I_sup again. Why isn't V_coil arbitrarily low? The resistance in the coils is negligible, so even at high currents, you shouldn't be generating much back-emf. The inductance of the coils keeps current recirulating, and ensures the currrent rises at a limited rated when a half-bridge is connected to Vcc rather than instantly spiking to Vcc/R_coil (R_coil being negligible),  but the inductance shouldn't be creating voltages in the coils which would apply here? The brief switching time for the current leads to a voltage in the coil of about 0.7 to 1.2V (approx) needed to overcome the diode in the half-bridge which points from the shared ground up to the leg of the BLDC, but that only requires the voltage for a very small fraction of each PWM cycle, and I paralelled a beefy schottky diode with it (rated for something like 0.4V at up to like 20A or so) with this part of each half-bridge.
So why am I drawing a whole 2A or so at Vcc=12V to get I_coil=15A or so (time averaged, peak during A part of PWM cycle being higher) reciruclating in coils which, at standstill or slow rotation speeds, have minimal voltages in them? I am PWMing at 7.8KHz, I'm not sure where one would put a voltmeter or an o-scope's probes inbetween to actually measure the "V_coil" I describe, but I have measured the I_coil using tiny valued high power semi-precision resistors as shunts and op-amp methods for amplification. I do know that my current waveform is such that I get a sharp rise in current when a half-bridge is connected to Vcc, gradient as according to 12V vs the coil inductance, then it exponentialy decays to nearly zero in time for the next switching cycle to happen. The system works, it runs fine, I can control the motor and am happy with it, but given there should be minimal voltage within the high-current coils, I can't see why I can't get an arbitrarily high ratio between I_sup and I_coil, subject to practical limits of the amount of current the coils and half-bridges can handle ofcourse, and atleast get I_sup down to something pretty minimal for the present 15A or so running round and round within the coils. If there's a clear reason why I'd like to know what it is? Why isn't V_coil effectively zero??
Thanks
« Last Edit: July 18, 2024, 04:16:54 pm by Infraviolet »
Re: BLDC buck conversion, where is the power going
« Reply #1 on: July 20, 2024, 03:28:56 pm »
Any thoughts? Thanks
Offline Slh
« Reply #2 on: July 20, 2024, 04:04:14 pm »
Your coils and MOSFETs have non-zero resistance giving you conduction losses (i^2*R) and a measurable voltage drop. You also have switching losses in the MOSFETs (every cycle a tiny bit of energy is lost due to diode reverse recovery and capacitance) and you have iron losses and magnet losses in the motor due to hysteresis in the material and induced currents.
You may also find that the 2A that you're measuring is not entirely accurate depending on what you're using to measure it and how much DC link capacitance you have as there could be a lot of ripple.
Online Conrad Hoffman
    • The Messy Basement
« Reply #3 on: July 20, 2024, 07:53:17 pm »
Q- Where is the power going?
A- What's getting warm or hot?
« Reply #4 on: July 20, 2024, 09:42:36 pm »
I should probably have titled the thread better than "where" is the power going, it is the motor which gets hot while the driver half-bridges stay pretty cool, but the main thing I'm trying to understand here is why I'm not getting much lower voltages within the coils. V=IR for coils of very low resistance should surely not be getting high enough that the power supply needs to provide a whole 2A at 12V (24 watts) (there is a lot of capacitnce in parallel with the power supply so the ripple caused when the half-bridges make a sudden draw of current, then stop drawing when they switch to recirculating curent in the coils, shouldn't be too much) simply to drive 15A (which, ignoring switching losses, implies a 1.6V voltage in the coils)  around inside the low resistance coils.
Thanks
Offline Siwastaja
« Reply #5 on: Yesterday at 11:06:06 am »
You are probably underestimating the resistance of the windings. If it is the motor which is getting hot, not the semiconductors or any other part of the circuit, then the resistance must be there.
So clearly the motor is dissipating ~20W or so at 15A coil current. Now really the only question is, is that 15A all doing useful work? If it's 90 degrees in advance to the rotor position, i.e. in FOC terms completely Q (not D) current, then it's all fine: it should be generating quite some serious torque. If the timing is off, then part of that 15A is recirculating between the motor inductance and your input capacitors and not doing physical work, but still causing those resistive losses.
