Author Topic: Dilemma: shrouded header 2x4 pin  (Read 2845 times)
Offline tiborsimonTopic starter
  • Country: hu
    • tiborsimon.io
« on: May 24, 2014, 11:01:30 am »
Hi guys!
It seems to me that the 2x4 pin shrouded headers are really rare parts (at least in Hungary :) ). Do you think it is worth to design a product with these headers?
Online David_AVD
Re: Dilemma: shrouded header 2x4 pin
« Reply #1 on: May 24, 2014, 11:04:46 am »
Connectors like that with less than 10 pins are way more expensive and really hard to find in small quantities.
If you have the space for the 10 pin version (2x5) you should go with that instead imo.
  • Country: hu
    • tiborsimon.io
« Reply #2 on: May 24, 2014, 11:13:08 am »
Yeah, I am using 10 pin headers in the current revision. Thanks for the advice ;)
Offline Monkeh
Online ajb
« Reply #4 on: May 24, 2014, 07:54:37 pm »
I've found Wurth to be reliable for this sort of thing.  8 pin shrouded headers are a standard part, so they should have them in stock with no MOQ.  Not sure how they are with hobbyists, if that's your situation, but our local rep has been happy to sell us 25-100 parts at a time.
Online David_AVD
« Reply #5 on: May 24, 2014, 11:14:56 pm »
That's a good price from that Aliexpress seller.  Just make sure you can get the matching cable crimps at a reasonable price.  :)
  • Country: hu
    • tiborsimon.io
« Reply #6 on: May 25, 2014, 07:16:08 pm »
Thank you guys for the answers. I realized, that I can fit in a 2x3 header too, which isn't as rare as the 2x4, so I would pick that. :)
I have another question. What are the benefits of a shrouded header? Do they worth the extra space? In my project I want to chain individual boards to each other. The headers and the corresponding plugs and cables will implement a common bus. It will be a modular human interface, so the connectors may get loose. But as I tried, the shrouded connectors get loose too. I used standard plugs/crimps and shrouded headers.
Offline Monkeh
« Reply #7 on: May 25, 2014, 07:17:31 pm »
Keying.
