summer is getting closer every day, and i have decided to do a new project.
A peltier-powered, soda cooler !!!! I have two peltier elements, and i also have two cheap CPU cooler's to cool down the hot side of the peltier. the cold side will be mounted to an aluminium alloy, carved to the shape of a soda can.
What i need help, for is the circuit. I want one thermistor (placed on the soda can) and a potentiometer to choose the desired temperature. If those two could somehow work together to turn the peltier elements and the fans on and off, to regulate the soda temperature, that would be awesome.
I would love to make it analog, but it's OK to have it digital, if that's the only solution
I hope you can help me! cheers, Iver
