Author Topic: DIY bench power supply PSL-2401/2  (Read 13853 times)
Offline LivTopic starter
  • Country: by
« on: March 05, 2015, 06:24:44 pm »
Features:
• output voltage: 0…24 V
• output current: 0…1 A (PSL-2401), 0…2 A (PSL-2402)
• voltage resolution: 10 mV
• current resolution: 1 mA
• operation modes: CV, CC
• down programmer circuit
• pure linear design
• multilevel output stage supply
• synchronous rectifiers (PSL-2402 only)
• digital calibration
• interface: USB (PSL-2402 only)
• case type: Z-4A (Kradex, poland)
4-ampere version here: PSL-3604
« Last Edit: April 09, 2015, 12:46:43 pm by Liv »
PSU PSL-3604 Pulse gen. PG-872 Freq. cnt. FC-510
The following users thanked this post: EU1, croma641
  • Country: by
Re: DIY bench power supply PSL-2401/2
« Reply #1 on: March 05, 2015, 06:30:37 pm »
Some photos.
Two last photos - main board with diode rectifier (PSL-2401) and synchronous rectifier using IRF7313 (PSL-2402).
Offline MoighonFweeman
« Reply #2 on: March 06, 2015, 02:12:53 am »
Cost?
  • Country: by
« Reply #3 on: March 06, 2015, 07:18:26 am »
This is an open source DIY project. The cost of parts can be calculated according to the schemes.
Offline prasimix
  • Country: hr
    • EEZ
« Reply #4 on: March 16, 2015, 10:45:21 am »
Please note that in document PSL-2401_sch.pdf page 3 and 4 are identical.
  • Country: by
« Reply #5 on: March 16, 2015, 02:29:45 pm »
Thank you, I made a mistake in the document got an extra page.
Offline prasimix
  • Country: hr
    • EEZ
« Reply #6 on: March 16, 2015, 04:55:52 pm »
Or it's missing what you have in PSL-2402_sch.pdf, a section with gate drivers and output mosfets (pg. 4)?
  • Country: by
« Reply #7 on: March 16, 2015, 05:23:12 pm »
Thank you, I fixed problem. Updated files:
Offline bitwelder
« Reply #8 on: March 21, 2015, 02:34:15 pm »
Beautiful project, thanks for sharing!
A few question, if you don't mind:
- is the PSL-3604 simply a 'higher power' version of these PSL-2401/2402, i.e. are the two projects using about same basic design? Or is it one project the 'evolution' of the other one?
- regarding the construction, is it just about build the boards, flash the firmware and it's ready to go, or is there a calibration procedure to follow?
  • Country: by
« Reply #9 on: March 21, 2015, 03:17:35 pm »
PSL-2401/2 is a somewhat simplified version of the PSL-3604. They have less buttons, less digits display. PSL-3604 has better usability, but it has greater size and weight.
When you turn on the power supply for the first time, the calibration coefficients are loaded by default. The actual output voltage and current will be slightly different from the settings on the deviation of precision resistors and reference voltage. The menu contains easy step by step calibration procedure that requires a reference external voltmeter and ammeter.
