No idea about the CHOP capacitor,
but why select this device if all you're after is a simple H-bridge driver?
Or, why don't you want to use current control? Much better control of the motor with less risk of burning the windings.
Also, many stepper drivers exist with the stepping sequence integrated, these can be controlled much easier using STEP pulses and Enable+Direction signals.
