Author Topic: Electronic load for battery cell testing  (Read 1982 times)
Offline m.kTopic starter
  • Country: at
« on: May 04, 2017, 11:00:28 pm »
New project, i want do build a battery discharge tester for single cell testing.
Specs:
-voltage range: 0-4,5V (full current sink should be available down to 2V, maybe 25-30A down to 1V if possible)
-current range: 50mA-75A (would be cool to have an universal setup that can either test an AAA NiMH battery for capacity and really push smaller Li-Ion -cells like 18650, 21700 and 26650 to their limits.) Should be able to switch off the current flow so the battery in test doesn't get overdischarged.
-data logging via a arduino and a computer (because i can't do proper uCs yet)
-temperature measurement and cutout
-input should be floating so you can test an 3,3V earthed powersupply with an earthed data logging/showing computer.
I never layed out an PCB before and have small electronic design experience (hey, i built a lab power supply with 2 LM317 ;D) so i may ask some rather dumb questions down the road when I'm at the board layout stage. But eventually I end up with a nice battery cell tester and share my design which may is helpful to anyone :)
For now i did search for components and started with the schematic, next up is ordering the parts and doing some breadbording as well as figuring SPI out. Then think a litte about decoupling and component values and finally layout.
« Last Edit: May 04, 2017, 11:03:47 pm by m.k »
Online nctnico
Re: Electronic load for battery cell testing
« Reply #1 on: May 04, 2017, 11:05:05 pm »
I'm missing a fuse in case the MOSFETs short due to a failure.
  • Country: at
« Reply #2 on: May 04, 2017, 11:15:15 pm »
I had a look at some automotive style fuses and already found some nice ones with low enough voltage drop to keep the internal impedance of the thing down. Going to definitely use a fuse :)
I thought about reverse Polarity protection, because i guess the MOSFETs would act like a short if one does reverse the polarity, but keeping the internal resistance down makes this not fully trivial. Goes in the "nice to have" category.
Offline VoltJesus
  • All your Volts will be save
« Reply #3 on: May 05, 2017, 09:43:30 am »
I started researching info on building one of these as well. Got a bunch of cells I need to test.
I'll be watching this thread to see how your project goes.
Online MarkF
« Reply #4 on: May 05, 2017, 10:10:15 am »
I'm building an Electronic Load (no microcontroller) based on designs put forth by Peter Oakes
and Dave Jones
Mine is low power but you should see Peter's design and how he blew it up because your load section is very similar.
« Last Edit: May 05, 2017, 10:11:52 am by MarkF »
