Author Topic: Bicolor LED connected series/cascade  (Read 1420 times)
Offline John AndersonTopic starter
« on: August 18, 2016, 07:38:28 am »
I was wondering if exists a commercial bicolor, 3-lead LED with internal connection of the 2 LEDs in series/cascade, so by having connected the 'extreme' leads to +Vcc and Gnd, and applying a digital signal to the common lead, the LED directly lights up accordingly to the signal without the need of any external circuitry rather than the limiting resistor.
Thank you!
Offline ludzinc
    • My Misadventures In Engineering
Re: Bicolor LED connected series/cascade
« Reply #1 on: August 18, 2016, 08:59:10 am »
A common anode Red / Green LED will work for you here.
Use the one resistor on the anode, wire the green to ground. Wire the red to your signal pin.
When the signal is high, Green will light. When low, Red will light (due to lower voltage drop across Red LED).
The following users thanked this post: John Anderson
