Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
DC Power Rating for Rotary Switches
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: DC Power Rating for Rotary Switches (Read 1810 times)
Farley
Regular Contributor
Country:
on:
June 01, 2013, 09:10:07 pm »
The rotary switches I'm finding are specified the current rating at a specific AC voltage. The application I have in mind would use one pole of a rotary switch to switch 12VDC with a maximum current of 2A. I'm not sure I understand how to determine the DC current handling capability of a specific switch when the spec sheet only specifies the maximum current at AC (usually 120VAC or 240VAC).
Here's a representative specification from the Mouser catalog:
http://www.mouser.com/ds/2/13/SR2511F-185523.pdf
My spidey sense tells me it is more complicated than simply computing total power handling and recalculating for 12VDC.
Logged
bilko
Frequent Contributor
Country:
Re: DC Power Rating for Rotary Switches
Reply #1 on:
June 02, 2013, 09:40:41 am »
I wouldn't exceed the AC current rating for the switch. It doesn't say if it is rated for inductive or resistive loads. I would assume resistive and de-rate accordingly for inductive.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
