Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Did OPA687 ever come in a dip package?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Did OPA687 ever come in a dip package? (Read 1438 times)
lincoln
Regular Contributor
Country:
on:
September 07, 2015, 03:59:28 am »
Hello,
I'm modifying an Extron ADA 4 300MX distribution amp to buffer 10MHz to various test equipment in the lab, basically tying the three RGB channels together, and populating the empty BNCs.
I'm trying to figure out what op amp they used.
There is no maker's mark, just the number 687J
Looking around the web, the closes that I could find was an OPA 687. Only thing is it seams that they wern't offered in a dip package. Other than that the circuit and specs all match.
What do you think?
link
Last Edit: September 07, 2015, 06:07:44 am by lincoln
Logged
DimitriP
Super Contributor
Country:
"Best practices" are best not practiced.© Dimitri
Re: Did OPA687 ever come in a dip package?
Reply #1 on:
September 07, 2015, 04:29:42 am »
My ADA 3 180 and gerry's ADA 6 300MX HV use the CLC409
http://gerrysweeney.com/tag/ada-6-300mx-hv/
Logged
If three 100 Ohm resistors are connected in parallel, and in series with a 200 Ohm resistor, how many resistors do you have?
lincoln
Regular Contributor
Country:
Reply #2 on:
September 07, 2015, 05:35:46 am »
interesting, mine was mad in '95 and is all through hole.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
