Author Topic: output of ald2332 comparator TTL compatible with dual supply?  (Read 1510 times)
Offline SArepairmanTopic starter
  • wannabee bit hunter
http://www.aldinc.com/pdf/ALD2332.pdf
Is the output of this unit when running on a dual supply +-5v going to be -5->5V or 0-5V?
I ask because the LT1016 I was using before put out a 0-5v even when running on dual supplies, I am not sure if this one does too?
« Last Edit: June 25, 2014, 08:16:59 pm by SArepairman »
Re: output of ald2332 comparator TTL compatible with dual supply?
« Reply #1 on: June 25, 2014, 08:21:11 pm »
nmv  I found it
