Here is a table of op-amps for your perusal
Op-amps
Max Supply Input resistance (Mohm) GBWP MHz Slew Rate (V/us) Input noise (nV/Hz) THD + N Common Mode Voltage Range Output Voltage Swing Supply Current (mA) common mode ground common mode Vdd Notes Package Price £
Common Differential +/- 15V 2mA 10mA
LT1361 36 50 5 800 Vdd-2, Vee+2 4 no no HF DIP8 6.77
LM6172 36 40 4.9 3000 Vdd-1.5,Vee+1.5 2.5 no no HF DIP8 3.47
MC33072 44 150 4.5 13 32 0.02 Vdd-2, Vee Vdd-1,Vee+0.3 Vdd-1.6,Vee+1.6 3.8 yes no Single supply, low side DIP8 0.6
TLE2141 TLE2142 44 65 5.8 42 10.5 @ 1KHz 0.01 Vdd-1.8, Vee-0.3 Vdd-1.3, Vee+1.3 2 yes no Audio, Buffers, low side DIP8 2.088
TLE2072CP 38 infinite 10 40-45 12 0.008 Vdd, Vee+4 Vdd-1.1,Vee+1 3.1 no yes Audio, Buffers, high side DIP8 1.668
LM4562 34 1000 30 Kohm 20 2.7 @ 1KHz 0.00003 Vdd-2, Vee+2 Vdd-1,Vee+1 10 no no Audio, Buffers DIP8 2.23
LT1632 36 45 0.001 Vdd, Vee Vdd-0.2,Vee+0.3 9.2 yes yes RtoR DIP8 6.456
LT1490ACN8 44 15000 17 0.2 0.07 50 Vdd, Vee Vdd-0.25,Vee+0.25 0.1 yes yes RtoR, DC, low power DIP8 3.432
LM7332 35 15000 21 15.2 15.5 0.003 Vdd+0.3,Vee-0.3 Vdd-0.2,Vee+0.025 2 yes yes RtoR, DC 8SOIC 4.104
LM7322 32 15000 20 18 15 0.005 Vdd+0.3,Vee-0.3 Vdd-0.25,Vee+0.06 2.5 yes yes RtoR, DC VSSOP-8 1.212
OP284 36 4.25 4 3.9 Vdd, Vee Vdd-0.2,Vee+0.125 2 yes yes RtoR DIP8 10.092
TL072IP 36 infinite 4 13 18 0.003 Vdd,Vee+3 Vdd-1.5,Vee+1.5 Vdd-3,Vee+3 2.8 no yes Audio, low nse, high side DIP8 0.84
LM324 32 1600 1.2 0.5 35 Vdd-1.5,Vee Vdd-4,Vee 1.4 yes no Single supply, low side
LM6132 24 210 11 14 0.0015 Vdd,Vee Vdd-0.2,Vee+0.15 1 yes yes RtoR, low power DIP8 2.99
OPA251 36 4500 0.035 0.01 45 Vdd-0.8,Vee-0.2 Vdd-0.05,Vee+0.05 0.05 yes no Single supply, low side, micropower DIP8 2.98
TSH22 36 100 25 15 14 0.003 Vdd-1.8,Vee Vdd-1,Vee+0.3 4.3 yes no Single supply, low side DIP8 1.44
