Author Topic: Bench Power Supply  (Read 1261 times)
Offline jamessinghalTopic starter
Bench Power Supply
« on: February 28, 2018, 05:34:42 pm »
Hey eevblog,
I have been working on the design for my bench power supply, and need help finding a useful schematic for it. I have been basing it off of the LT1084, but the schematic on its data sheets contains 2 transformers without information about them. My main requirements are at least 0-30v and at least 0-5a. I mostly have the voltage control done, but the part that I can't figure out is the current limiting control. I don't want to use a potentiometer because of efficiency, and I want to use something similar to the circuit that a mainstream power supply (BK precision or Rigol) uses to accurately limit the current.
Any help is welcome
Thanks,
James
Re: Bench Power Supply
« Reply #1 on: February 28, 2018, 11:25:28 pm »
I found the LT3080 but don't know how to effectively use it. Are there any other good schematics for lab power supplies?
Offline CopperCone
  • *knock knock*
« Reply #2 on: March 01, 2018, 05:26:02 pm »
Dave jones had an entire seeries on his early usupply using lt3080
Offline cellularmitosis
« Reply #3 on: March 02, 2018, 06:57:28 am »
Didn't he run into a problem with the LT3080?  Was he ever able to figure out a solution?  Something like it became unstable under certain conditions?  It seemed like it killed his uSupply project.
LTZs: KX FX MX CX PX Frank A9 QX
