The left divider 12/2 gives an output (6.95*(2/(2+12)) which is a bit less than 1 volt and has internal resistance a bit less than 2k. Adding the 20k in series increases the source resistance to some small 22k. The 100k trim and the 2M makes a 6.95 volt source with resistance a bit more than 2M (a hundred times greater than 20k). So the trim will be able to alter the summed voltage with around 1 %. The right side 2k buffers the op amp and is small in order to not disturb the balance of the op amp bias (the two inputs should see appr. the same DC resistance, hence the left side arrangement so-so balances the 22k feedback resistor).
