They call them moving coil meters!
A small analog meter won't draw a lot of current,& you can usually find extremely tiny ones in junk pieces of equipment,where they were used as audio level meters.
I think most of them are around 50uA FSD (but you can set a lower scale reading if that is too much!)
You may have to mess around with series resistors to get what you want.
Obviously,this is what you would use for a "one off" project,& if you are making thousands they may be hard to get in those quantities.
The other thing you can do,is teardown your toothbrush & steal the LCD!!
