Author Topic: Return Loss of SMD Resistors  (Read 1314 times)
Offline ocwTopic starter
« on: May 31, 2017, 03:34:35 am »
After stumbling into an old article in Electronic Design (see http://defenseelectronicsmag.com/site-files/defenseelectronicsmag.com/files/archive/rfdesign.com/mag/511RFDF3.pdf ) I decided to complete a similar evaluation of the SMD resistors which I already have in stock.  I measured the resistor's return loss and its series resistance and reactance from 5 kHz - 900 MHz.  Stray reactance in my test procedure invalidates readings above that frequency using my Array Solutions AIM-UHF impedance analyzer.
For a simple beginning I thought that I would start with my 1k resistors.  Most axial resistors with values of around 200 ohms and under have reactance which don't significantly affect its impedance up to the mid-VHF frequencies.  It becomes hard to find axial resistors with values of 10k and above which aren't seriously limited by their reactance.
The Panasonic ERJ-6ENF1001V resistors were the clear winners in the 2012 size SMD category.  The Arcol/Ohmite APC0603B1K00N were significantly better than my economy Yageo 1608 resistors.  I threw in some axial resistors for comparison.  They came out better than I expected.  The IRC/TT CMF1/41001FLFTR resistors were the best of those available.  Other brand/model axial resistors of different values which I have had significantly worse performance.
I'm not sure who made the EF Johnson numbered resistors which I included in the tests.
I have many other brand and model SMD resistors in other values which I didn't include.  I skipped the 988 and 1,010 ohm resistors which I also have as well as many more additional values.
For reference I also included my evaluations of two of the RF resistors which I have.  I included the Vishay 50 ohm FC0603E50R0BTBST1 20 GHz 0.1% and 221 ohm FC0805E2210DTWS 20 GHz 0.5% resistors.  Check out the attachments below.
