another solar road way type technology.
http://tanktwo.com/
https://youtu.be/8BAk4l98GtY
I think its a Gimick, low energy density (casing and air gaps and electronics) and low current path due to point contacts and random connections will mean random voltage ranges.
1) the best way to convince you would be to make you read the patents. It is heavy duty legalese mumbo jumbo, but the facts are there in all the glorious detail.
2) Let's do some numbers. The casing shape is an ellipsoid, with a very specific semi axis ratio (approximately 1.2:1:0.
which is the shape with the
highest known random packing density of any shape. It beats cubes, spheres and everything else.
Here is an interesting reference for you to dig into if you don't buy that argument to begin with:
http://mathworld.wolfram.com/EllipsoidPacking.html Wolfram alpha is cool, but after that read also the M&M packing density paper (fascinating, and you get to eat the experiment afterwards). By the way, the internal code name for the String Cell is "candy". We're not big on poetry, it's ok if you think that's lame.
So: "our" ellipsoids have a random packing density of approximately 76%, which we round down to 73% due to "wall effects" in small "tanks" and the process which is not perfect.
Next, the shell is already less than 10% of the volume at the current size (and there is lots of room for improvement). We also use a couple of percent of the volume for the PCB and the ASIC. Leaving, conservatively, 60% for electrodes and other real battery stuff.
Compared to a regular battery pack, that's pretty damn good to begin with, because the 20-something percent which is "lost" is used for cooling, something which other packs need to do too.
And a cylindrical cell, or a pouch cell for that matter, needs a casing of some sort too, which is arguably less in volume than our current plastic cell, but it is really not much to begin with - we're just a few percent behind already now. And we have our ways of filling that space entirely, batteries are not always rectangular or cylindrical - think wrist bands for wearables)
But, only then the things get interesting. We don't need an external BMS (battery management system), because it is integrated and distributed.
1) We don't need bus bars or thumb-thick cell wiring (a Tesla Model S P85D, to take a rather cool example, draws a bit of current when it is putting that Lambo Aventador to shame in an acceleration test). [Note: I'm not saying that the P85D has bus bars in their pack, but it is a nicer visual image than the Nissan Leaf. (Hi Nissan, I promise that if you want to buy our batteries I'll never say that again in public)].
2) We use light plastic tanks with no rigidity requirements, which are a major issue if you have a half ton plus pack. You can't have 7k cells sloshing around in a standard pack. This saves space, but more importantly a LOT of weight. Weight is harder to save on when you design a BEV.
The list is much longer beyond this, but from this point onward we are already on parity with the legacy systems.
Not all cells will be used as only those that meet the algorithm.
Well yes, obviously. But the exact utilization rate is what matters. And of course one of the things that the company is making money of is by developing algorithms that make better use of packs.
About the absolute numbers: even with simple routing algorithms (Think Dijkstra algorithm, which we all have learned in school, you can get already 90%+ utilization rate. Easily. Of course this depends on a boatload of other parameters, such as number of contacts on the string cell, placement of contacts, size of the "air gap", size, shape, number of channels (the contacts placed to the walls of the string battery, which is the enclosure or the "tank" if you will), and a ton of other variables. Getting close to 100% is easy, although admittedly not intuitive. Simulations and hardware prove it though.
This is basically a box of dry joints, any vibration would cause intermittent open circuits and arching.
Nope, wrong. Two reasons:
1) the dense ellipsoid packing naturally leaves little empty space, which also means there is little room for rattle. If you just fill a container, and shake it violently, you can barely hear any rattle to begin with. This is also not intuitive, but it's basic physics. In geometrical terms it is simply a matter of degrees of freedom. Think shaking a bag of sand vs. a bag of marbles.
2) the string battery container has a silicone bladder, which is pumped up with compressed air. Even with modest pressure applied, the string cells remain rock solid in place. The G forces found in a normal passenger vehicle don't come even close to what is needed to even marginally upset the arrangement.
3) contact resistance is a well understood section of engineering, as the connector wasn't invented yesterday. You need surprisingly little mechanical force to achieve an acceptable contact resistance value, if you use the appropriate alloys. In the early prototypes, we used gold. That works well, but is a little on the expensive side. Tinned copper, for example, has worked very well - a little bit to our surprise admittedly. Apparently the oxidation effects don't harm operation at all, and contact resistance is in the milliohm range. We probably won't use tin much going forward for certain reasons, but it is an illustration.
4) the string cells are smart, meaning they measure and control stuff, and also measure the current going through their contacts. The connections go through N-channel power MOSFETs, and when contact pressure is accidentally reduced and contact resistance goes up, the power FETs have disconnected the load long before the mechanical connection is severed. Hot plugging and unplugging requirements are nasty on connectors, but we remove that requirement by anticipating "hot unplugging" events it and removing current before it can cause a spark. It's surprisingly simple.
with most energy density you want the most chemical in the smallest volume, thats why you use liquids or powders or gels/pastes
Sure. That's why you won't see the Boeing or Airbus Leaf soon.
hell of a lot easier to just transfer electrons at high current and voltage then transfer battery balls.
Of course. That's why a car with our batteries can still be charged in the same way than any other electric car. And even when you have the capability to swap them, you won't do so most of the time.
Is there any spec on the cell? Ah capacity? dimensions? volume?
Of course. We don't quote capacity without NDA because there are variations on the battery chemistry options with impacts on price, longevity, peak current, and other parameters. But there is nothing special going on there, the battery chemistry are variants of the "standard" Lithium-ion cells and all options are available to our customers too.
I smell BullSh!T
Try getting new firmware for your nose.
Thanks for the feedback anyway. This will only make it better!
Bert
