Author Topic: Reprogram a bitcoin asic miner for something useful?  (Read 6337 times)
Offline teqmoTopic starter
« on: June 10, 2014, 06:37:16 am »
I have a bunch of these 330mhs asic miners wanted to know if I could reflash it to do something?
Offline senso
  • Country: pt
    • My AVR tutorials
Re: Reprogram a bitcoin asic miner for something useful?
« Reply #1 on: June 10, 2014, 06:40:05 am »
If they are asic's the algorithm is set in silicone, you can only reuse them if they are FPGA based.
Offline AndyC_772
« Reply #2 on: June 10, 2014, 07:15:44 am »
The clue is in the name: Application specific integrated circuit.
Offline nuno
  • Country: pt
« Reply #3 on: June 10, 2014, 08:34:29 am »
I guess you meant silicon  :-DD
Offline rolycat
« Reply #4 on: June 10, 2014, 09:08:46 am »
I reckon setting algorithms in silicone is a great idea.
Fuzzy logic is kind of old-hat now; this could be a whole new field - bouncy logic  ;D
Offline amyk
« Reply #5 on: June 10, 2014, 11:02:48 am »
Depends on how "specific" that ASIC is.... at best, it would probably be usable as a SHA256 accelerator, but not much more than that.
Offline Dago
    • Electronics blog about whatever I happen to build!
« Reply #6 on: June 10, 2014, 11:48:48 am »
I *think* Bitcoins use double SHA256 so AFAIK ASIC miners would only be useful for applications requiring two rounds of SHA256.
Come and check my projects at http://www.dgkelectronics.com ! I also tweet as https://twitter.com/DGKelectronics
Offline rob77
  • Country: sk
« Reply #7 on: June 10, 2014, 12:01:44 pm »
you can use them as heating elements :D controlled by the clock - the faster the clock the more heat they will produce :D
sorry but there is no other usage for those devices.. the fpga is an fpga - you can burn in whatever you want... but asic is hardcoded silicon.
Offline miguelvp
« Reply #8 on: June 11, 2014, 08:39:26 am »
I don't know I like my asic's voluptuous. ;)
Offline amyk
« Reply #9 on: June 11, 2014, 10:42:01 am »
Like I said it depends on how specific they are - if I remember correctly, the early ones could do single rounds too.
