I've played with Cambridge Silicon Radio modules (Now owned by Qualcomm) like csra64215, csr8635, adding bluetooth to mine and some friends's cars.
Try to get aptX modules, that's the best quality you can get (lossless audio).
Since it became Qualcomm, a lot of previously freely available software became NDA or for customer-only.
You can still find them in the
>web<...
Programming them is a bit messy, you need a specific CSR USB-SPI adapter, and the software is a bit tricky.
Someone made
>bluemagic<, based on a stm32f103 bluepill, emulating the CSR programmer, but the bluepill only "talks" 3.3V, while most of these bluetooth SOCs work at 1.8V, using resistor dividers didn't work.
Ended using a TXS108e logic level translator, then it worked.
However, these modules get bricked extremely easy, beyond recovery!
They feature a 1.8V-only SPI flash, backup its contents before anything else, so on the event something goes wrong you can restore it.
Use another TXS108e if your programmer doesn't support 1.8V, I did that way to interface my CH341A.
Once you have a backup, there's no fear!
I probably bricked it 20 times
![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/cheesy.gif)
On the first try, I changed the bluetooth name, worked nicely... but then touched something else and killed the module, had to buy a second one to dump the flash contents and recover the first one!
