Hi gang,
I'm considering putting together a design schematic for a linear DC 13.8V power supply used for Ham Radios. Many linear DC supplies for Ham Radios make use of the famous LM/uA-723 voltage regulator chip. After reading through a few posts here related to the 723, I'm considering using a different regulator. For my Ham Radio requirements, typical load current will range between various radios between 9A-23A, therefore I'm planning for a PS capable of providing up to 40A 100% duty-cycle max. However, typical max current load will likely never exceed 25A at 100% duty cycle.
Strongly desired regulator specs would include:
- Adjustable output voltage (either via built-in pin(s) or external resistors)
- LDO
- Low output voltage noise (perhaps <80µVrms)
- High ripple rejection (perhaps >50dB (100 Hz)
- Input voltage range of 18v-35v (wide range because I've never worked with a LDO regulator and not certain how much drop is associated and/or specified for stable and safe operation)
- Current limit protection (short and reverse protection)
- Over-voltage protection adjustment to protect the radio(s).
This is a big ask, and is my first forum post, so I'll apologize now for saying or asking stupid things, *grin*.
So far, in my search, I've come across two possible regulator candidates. What are your thoughts and recommendations?
1. TPS7A4701-EP:
https://www.ti.com/lit/ds/symlink/tps7a4701-ep.pdf?ts=17244899320332. UC2834M:
https://www.ti.com/lit/ds/symlink/uc2834m.pdf?ts=1724513506097&ref_url=https%253A%252F%252Fwww.ti.com%252Fproduct%252FUC2834MI appreciate any input you provide, have a great day!
