@Warhawk can you share more details from your experience and a suitable alternative?
TI doesn't tell us what diodes are used in the OPA2333
(writing the post the second time as i accidentally closed the tab
![Scared :scared:](https://www.eevblog.com/forum/Smileys/default/scared.gif)
I am sorry it took me longer to reply.
Using Schottky diodes is relevant, they just need to be carefully selected. I checked some of my designs and the 1PS79SB70 device from nexperia is frequently used. Check the DS. Alternatively, I used BAS40 (still not perfect). I am with the team red, therefore esd protections such as
TPD1E series find often place on my boards. Note the maximum 10nA leakage. They are intended for digital signals but work for ADC protections too.
[Thinking aloud]
I also wonder, if protections such as D12, D1, D3 are really necessary. I would maybe add only 22pF ESD caps on the input and call it good to go. The current to the input pin of the ADC is limited by series resistors. This reminds me that it is important to find out if S/H time is long enough.
Reverse polarity protection is maybe something I would like to see. D9 could be only unidirectional. Reverse polarity on the input would blow the fuse. Nevertheless, it would be likely more elegant to use an N mosfet + PWM charge pump from the MCU. That's often used for in automotive.
I also wonder if using the OPA2333 makes sense here. I see it is configured as a difference amplifier here. This gives us ~60dB CMRR top. There are maybe parts for this. I like that the author used the charge bucket filter C15, C16. Not all opamps like transients when S/H circuit opens. There is often ringing.
Regarding the diodes and TI.
OPA333 datasheet, the chapter 7.3.2, describes the protection. Normally, we do not specify (characterize) ESD cells on the input as they are not intended to be used for operation. (there are few exceptions). What matters is the maximum input current to the pin. This is defined in the Absolute Maximum Ratings, chapter 6.1. I believe there's a typo 1 vs 10 mA (see the note 2).
