Some of those "smart" chargers do not output constantly. They switch the output on for a while, then turn it off and measure the battery voltage. Then repeat.
Also the ones with a mode that claims to revive dead batteries usually apply voltage pulses significantly higher than 14 volts.
If you have a scope and suitable dummy load (eg a headlamp bulb) I would test before trying on the Riden.
