I wonder if you can get those numbers waaaaaaaaaaaaaaayyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy dowwwwwwwwnnnnnnnnnn
like so the scale is us or ns.
How about just dropping a heavy bar of lead or very anneled copper into a set of hardened forks in a pool of liquid metal, with gauge block level surfaces and alignment
I have been looking to do something meaningful with my gallistan. If you clean it and have it under inert gas it should work like mercury.
But I think with mercury, you get god damn surface tension problems, meaning your "level" is gonna be random based on fludics. if its dry you can align everything nearly perfectly if you spend enough time
I was reading about the history of relay developments and I feel like we have not even scratched the surface of what is possible.....
There must be some quantum limit that you would reach for timing a matched pair with sufficient precision based on tunneling and distance.... at least at first
that is eventually when your mechanics are precise enough, your main source of error would be the quantum tunneling that occurs when they are REALLY close together, I think that is inherently random. So that is like a 'fuzzy region' that we don't know how to compensate for yet. anyone wanna do a number crunch real quick?
