Since your links are to ebay.ca, implying Canada, then another alternative is Active Electronics which has the FX888 on sale right now for $99.99 ($40 off). I bought it back a few months ago when it was on sale for $88.88. Mine came with a 1.6mm chisel tip. This will save on shipping and handling and if something goes wrong, you take it back to Active.http://www.active123.com/FX88829BY-Soldering-Station-Prodview.htmlActive's regular price is a complete rip-off (not as bad as the 220V customers, but still it is 50% higher than what USA customers pay).If you don't live in a big city, another Canadian mail order for the FX888 is ($98.95)http://www.solarbotics.com/product/44162/Shipping might be a bit cheaper?
I noticed that there are two models available FX888-29BY/P and FX888-23BY.
I'm in the Toronto area
Quote from: Crush on July 19, 2012, 08:50:00 pmI noticed that there are two models available FX888-29BY/P and FX888-23BY.The only thing I know about the model number is that the BY stands for blue-yellow, the most common case color combination the FX888 comes in. As for the rest, no idea. Ok, well, the 888 is a lucky number in China, so many manufacturers try to use that for some product.
Quote from: Bored@Work on July 20, 2012, 04:56:27 amQuote from: Crush on July 19, 2012, 08:50:00 pmI noticed that there are two models available FX888-29BY/P and FX888-23BY.The only thing I know about the model number is that the BY stands for blue-yellow, the most common case color combination the FX888 comes in. As for the rest, no idea. Ok, well, the 888 is a lucky number in China, so many manufacturers try to use that for some product.Ok I got the answer:"Hakko made the 29BY with a special packaging sleeve. They are the same unit so buying either one will get you the same item. Thanks."So that's about it.
