Author Topic: Automotive Logic Output Protection  (Read 1521 times)
Offline RerouterTopic starter
« on: May 29, 2016, 02:52:17 am »
I'm in the process of making a in circuit diagnostic tool, that uses a bank of 1.8-5V logic outputs and inputs, Now the inputs i have covered pretty easy,
But i'm a bit stuck on finding a magic do it all buffer that can output those logic levels, and also be protected against +-32V on all outputs (E.g. if output voltage exceeded go high impedance)
Output drive specs would be 1.8-5V logic with 8-15mA sink / source.
Ideally I'd like it to survive being hooked up back to front across a truck battery, (how the previous model died)
« Last Edit: May 29, 2016, 03:05:07 am by Rerouter »
Re: Automotive Logic Output Protection
« Reply #1 on: May 29, 2016, 06:47:27 am »
sorry but the jfet option looks to drop too much voltage to be any use here,
I did start to find the keywords i was looking for, e.g.  https://www.maximintegrated.com/en/products/interface/circuit-protection/MAX4505.html
His maximum on resistance is still a little high for my liking, but its a start in the right direction,
Hmm another case of always read the datasheet carefully, minimum single supply voltage is 9V,
« Last Edit: May 29, 2016, 07:27:51 am by Rerouter »
« Reply #2 on: May 29, 2016, 07:43:45 am »
Ok furthur looking has found better options with analog devices, looks like the 9V minimum is pretty fixed, (and there is a quirk where the positive trigger has to be between VCC and VCC-4.5V, Which means a charge pump splitting 5V to +-5V makes an ideal solution, low RSon, and a wide protection range,
I'll leave this up for any who come later,
