If any one shares my fear that the New holster of the 87-5 (87V) ,
that it looks and feels like to be ready to flip over, due poor design ...
By looking the above pictures , you can be aware of, what you need to do as correction.
The plastic part , its part of one machine that is used to cut grass , the ones with the rotating string .
Actually its the round shield of it .
Its from the hardest unbreakable plastic .
Found it accidentally, same color as the Fluke, the transformation - construction took as two hours,
but it worthed it ..
The DMM become sturdy as a Rock ... this patent has zero impact as damaging factor,
the holster clips on it , with out pressure or force ,
and the only must do , are the slot to have an accurate length, with minimum free play.
Now you can congratulate me.
Dave I do not have a second one
