What would be your method for implementing a buck that simulates a resistor feeding into a large super-capacitor?
My end goal is to set a resistive equivalent load by MCU DAC. My initial thoughts were to use an op-amp deriving a target using the dc & dac, which is compared to a high current sense, which drives either a comparator for hysteretic mode or triggers fault on a fixed duty PWM signal.
But perhaps there's a more appropriate way...?
