ATX power supplies are generally pretty noisy. They also have extremely high current output on the primary rails (3.3, 5, 12), which can make them a fire hazard if used improperly. You can certainly use them to power circuits, but you need to use fuses to protect your wiring, and add additional filtering and post-regulation to get something quiet enough to use for analog electronics.
