I have a mixed signal multiboard circuit, and I am not sure on what the best way to design the grounding would be.
The first board is a 4 layer board, with a ground plane and power plane layer. Digital power is kept separate from the analog and there is a single ground bridge joining the two ground planes. All the mixed signal connections run over the ground bridge on this board. There are 2 board connectors for the sub circuit to connect with, sitting above the ground bridge, set up similarly (ground layer, power layer, ground bridge connection with all mixed signal traces running over it)
Now as you can see I have a ground loop between the bridge on the main circuit, and the bridge on the sub circuit. How do I avoid this ground loop, while still being able to run mixed signal lines across from the digital to the analog planes over a bridge? Would I have to run all signals back through the connector, and cross over a single bridge? That could make for a massive connector!
HELP!
