You never specified that it is suppose to be a temporary arrangement.
Assuming the areas where the thermocouples measure will not be shorted out, cover the thermocouple tip with heat transfer compound.
Use capton tape to hold the thermocouple wire down, bend the thermocouple so that the tip touches the area you want to measure.
