Hello everyone,
I was recently able to use my university's microscope to observe some ICs (it is a microscope used for materials ananlysis. I am not studying materials or electronics by the way). One of the component was a BS108 MOSFET in a metal can. I am currently trying to analyse its structure but I am having some difficulties and I hope you can help me
First, here is a shot of the transistor:
I was able, using a mutimeter and the datasheet, to identify some of the pins/wires.
Here is a drawing I made to make things clearer:
Finally, some datasheet (for example this one, pdf:
https://www.bucek.name/pdf/bs108.pdf) describes it as a vertical n-channel enhancement mode DMOS. One of my resource gives a structure for this type of transistor:
http://www.circuitstoday.com/double-diffused-mos-dmosSo, I made this cross section view of the transistor but I am not sure that I have the correct structure:
I am sure about the position of the gate, the source and the case (datasheet + multimeter). But I am not the sure of the shape of the cross section, the structure (letters) and the type of material / regions (numbers). Are my guesses corrects ? Do you have any idea ?
Thank you
PDU
PS: It's my first time posting here, so I am not sure this is the right place. Tell me if anything is wrong (image size, image host, forum,...)
