I'm playing with AS5600L position sensor breakout board, AS5600L-WL_EK_AB, the one with the WL-CSP footprint.
I've connected it up to the AMS tools - USB I&P Box. It shows the device working - the I2C interface shows the registers and current position.
If I set it to PWM mode, my scope shows the PWM signal on the OUT pin changing as I change the magnet angle.
But, if I set it to analog mode (VDD), I only get the full voltage on the OUT pin. I expected the voltage to be between 0 and VDD depending on the magnet angle. I've tried pull up and pull down resistors, without any luck.
Has anyone used these? Is my understanding of the analog output incorrect? I contacted AMS technical support but they just redirected me to local distributors (mouser, digikey, etc)
