How are you programming the blue pill ?
I have some here but haven't really got a usable workflow for them. But I have got a logic analyser and even one of those old HPIB analysers bitseeker mentions.
(very puzzled as to why I was entering a newline every time I hit '?'. Thought it was the forum software but it was because of a bit of hot glue that had fallen between the shift and return keys ...)
Everytime I receive a new one, I perform these steps to install the firmware from stm32duino:
1. I connect a FTDI to the blue pill
2. I move the "upper" jumper to 1
3. I connect the FTDI to a USB port. I verify that it appears as "Prolific USB To Serial Port (COM 6)" (6 or whatever other port)
If this step fails, I download PL2303_64bit_Installer that installs version 3.8.18.0 (this one works for Win10)
4. Then I go to "C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\tools\win"
5. I then execute this line: stm32flash.exe -w ..\..\STM32F1\binario\generic_boot20_pc13.bin COM6 (6 is an example, you should use the previous port)
6. I shift the upper jumper back to "0"
Then I use the arduino IDE with the following settings (in the "Tools" menu):
Board: Generic STM32103C
Variant: STM32F103CB (20k RAM, 128K Flash)
CPU Speed: 72MHz
Upload Method: STM32duino Bootloader
Sometimes when I'm uploading the sketch it gets stuck waiting for the DFU interface, if that happens I quickly reset it (so it starts in DFU mode) and that's enough to make it work.
If you have any doubt on the steps or the files needed let me know
